C&C are welcome
Re: Public Building
just put some framing on glass to make it more realistic.. ;D
Re: Public Building
judge,
the 2nd image rendering and composition is excellent. you set up the camera, and you have great success in using those diagonal lines leading to the building thats really good. i also like the shadow caasting with those group of people and at the same time placing another isolated guy stiing on the left corner, thats a pretty good balance of composition. Now for the first image, i think its the opposite. you need to work out the composition. the ambient ligthing is too warm and dull. those plants mmm? im not sure though, the fountain seems floating and the reflection is unrealistic.
Re: Public Building
JudgeBao,
Thank you for the comment
The idea of the curtain wall is that the framing is on the internal side of the building. I will try to put the framing so it will be visible from outside view.
nomeradona,
Thank you for your comments, they are very ‘eye lightning’. I’ll work on the composition of the 2nd image.
I’ll post the resoults as soon as i finish.
Re: Public Building
excellent, the last image is absolutely much much better. is it possible to share your visopt on the last image? just for comparison study.
Re: Public Building
Great image. I have a question, are the reflections are billboards or in the environment slots? I cannot do the same reflection as in yours.
Re: Public Building
This one it’s more “vivid”, I don’t know if you modified something…but I can’t really give you a good critic, because exteriors are for me a virgin land , if I can say so… I know interior are easy..so congratulation for your work. Those ruby’s are.. something, I’m using lot’s of them myself.
Cheers!
Re: Public Building
very nice enviroment tecnic.
Re: Public Building
stefanq,
Thanx man. This time I used a bit different adjustments in Photoshop.
andeciuala,
Thank you, i hope to keep improve my scenes in future, and your comments were very helpful.
Re: Public Building
i like your layout the 40th. and its really a good way on maximising the strength of su, and lo man vray is very powerful in acquiring environmental reflection very effective.
perhaps my request for to help other guys here is to make a small tutorial about this and put it on the tutorial section. im sure this posting will be forgotten, but there is a huge thing here which would be beneficial to everyone. hope you dont mind.
Re: Public Building
nomeradona,
Thanks for the appreciation, it realy means a lot to me.
I’m not sure that i undrstood what the TUTorial should be about?
Re: Public Building
that reflection of those block houses…(see your set up) bill boards with all those houses. the title is how to get realistic reflection by adding those block houses around.
of course hdri is one thing, but your set up i find it useful too.
Re: Public Building
nomeradona,
I made a tutorial on the topic. Check it out at the Tips, Tricks, and Tutorials Section
Re: Public Building
yeah, i went there and i love your turorial there. im sure many peolle will benefit from it. thanks 40th.. i hope many more will follow yuor footstep.
Re: Public Building
No Problem Nomer, i’m glad that i could to contribute.
