Question about Distributed Render
I just set up DR it works pretty well , i think
problem is
“When i use DR it works only at the servers on the list
Is it possblie to use the client computer together with servers?”
Yes it should work. Run the DRWizard utility to configure DR on the client computer and then start vrayspawner. Then click “add server” and put in the IP address. The client computer becomes a server.
thanks for reply,i will try…
