Hallo everyone,
I have a question about VRay for Rhino (Vers. 3.40)
as you can see in the picture, I don’t see the Toon contour of the windows and facade behind the Toon material with transparency (Opacity is set to 0).
There is an option, or another kind of transparent material, that allow me to see the all Toon contours of the building??
Thanks in advance!!!
Thank you for bringing up this issue. There are a couple of problems with Toon’s outlines and transparent materials which unfortunately will not be fixed in the upcoming update.
The only workaround I can advise in your case right now would be to have the trees’ outlines be actual faces (a few cm can be easily offset) and have a generic dark material instead of a MtlToon with transparent base material.
Kind regards,
Peter
