ill say it again, do any of you guys get the same issue with the adaptive sampler? cos i had exactly this issue on a recent job, and could just not get it clean without stupid 100x longer renders. switched from progressive to adaptive and the problem totally went away.
Hm, I guess a part of the problem is that the adaptive sampler also adapts to the alpha channel, whereas the progressive one only looks at the RGB and totally ignores the alpha.
i never used progressive for this scene…alway adaptive and unless i set the settings to the above mentioned, it noisy as hell.
the problém is only very evident if your bacplate is very clean…then the alpha noise is very evident and appears as atrifacts.
Hmm - weird that you didn’t get good results when you had the msr at 80 earlier on, it must have been the noise threshold dropping to 0.002 that made the big difference - maybe matte shadow objects over a dark background aren’t being “seen” by the renderer as seriously as non matte objects or since they’re being multiplied down by their alpha they’re easily meeting the noise threshold you’ve set? Per object subdivs / per object AA would be handy for this, especially if it’s a noise threshold issue. Must add this to the list of things to look at.
John…happy to share stripped down scene with a teapot instead of the character ![]()
i must say i have always had problems with noisy alpha and only this time i finally got it working although the rendertimes are not magical ![]()
If it’s only a teapot and a hdri light source I’ll have a look over here using something similar. Since it’s a common enough occurrence for all 3d artists it’d be worth me spending a bit of time at!
Well I found my cause, not sure if it’s the same as others. In the interest of posting a sample I started deconstructing my scene and in the process determined a cause: VrayExtraTex Render Element w/ VrayDirt & the “consider for antialiasing” + “affect matte objects” options. If both of the checkboxes are enabled, then my alpha gets noisey and the shadows lose samples according to the SampleRate RE. I don’t understand the implications of these options enough to know if that’s ‘as designed’ or a bug. Max 2016 Scene attached. Just watch the SampleRate render element. In it’s current setup, it renders as you’d expect, sampling the shadowed area more. As soon as you toggle on the consider for antialiasing, then you see the samples redistribute. Aside from adaptive sampler isntead of progressive, everything else should be at default as I reset the renderer during troubleshooting.
vray AO affects image sampling.zip (66.4 KB)
Thanks, I will make a note to look into this. In general though, I usually recommend doing the AO in a separate pass - it requires way too different sampling from the main RGB image and in most cases just slows down and confuses the renderer.
