RAL colours are often specified for cladding etc. It would be nice to be able to choose specific RAL colours from a list. Anyone know of a script or plugin that allows us to do this with Max and VRay?
Hi Tricky,
apart from the old ink (reflective) to RGB (transmissive) problem here are a couple of sites I use to get me close then eye it with RAL charts.
Compare | EasyRGB (does a lot of other stuff too)
http://www.ralcolor.com/ (be careful because the RGBs aren’t the same as the above site)
I’ve also been looking at this little thing but never quite felt it was worth it:
http://www.xrite.com/custom\_page.aspx?PageID=212
I also have a max vray mat library of RAL colours all set up, can’t remember where I go it (it was a freebie - i think) but if you pm me I will post it to you (650kb)
cheers
Hi Tricky,
you can try free scripted Texmap plugin: About Us - Siger
excellent! I’ll try that too. ![]()
Small update of a RAL Color Solid plug-in: http://www.sigershop.eu
Your links are broken where can I get this script ? Please can you profide a direct link to it ? Thanks.
I am using this one:
Digging up this ancient thread for RAL
Any other script/plugin options available for this?
There’s a ton of web based converters, but it would be nice if there’s something in Max 2019 that can work
