Hello
We’re facing come crazy random bug, we can hardly isolate … please check the enclosed cropped images to see the weird result ! FYI, the others renderings took about 1h30, whereas the bugged ones took between 8 - 9 hours !! We’ve ran the failed renderings again, and no problem … I hate random bugs
We’re working on 3dsmax 2014 x64, VRay 3.00.07.
Do you guys have any idea about what could be causing that ?
Do you happen to have 3ds Max Standart materials in this scene ? Also if you look at the pixel info in these green areas - is it some normal value (0.0 - 1.0) or some huge number ?
I’ve seen similar random artifacts with a scene with lots of standard materials.
You mean a pre-rendered IrrMap saved on disk ? if so, no
We had to switch on several other projects, so this problem is on my to-check list ! I’ll try to get more infos about it.
