When I have more than 1 light select render element, and I send a render to the farm, the first light select render element doesn’t render. Is this a known bug? where do bugs get submitted?
Try a few things:
1. Make sure each light select element has a different name - If they’re all vray_lightselect then it can cause one element to be overwritten by the other, or at least it did when I tried to have multiple vray_zdepth elements with different settings in a single render.
2. If you’re going directly out to exr, try rendering to vrimg and then converting to exr after. I’ve had some problems in one company with elements dissappearing which is likely down to a shitty network, but going to vrimg has worked 100% of the time.
Hopefully it’s the first!
Renaming each one did the trick, Thanks!
