RDK (formerly RCM) Wishlist
rhino skylight support
not sure if this is the right place, this is part of a little chat i have in the rhino NG:
>The skylight option disappears when the current render engine doesn’t support it. Vray doesn’t support the skylight.
    >-- Andrew le Bihan Robert McNeel and Associates
>> Hello, >> >> since I got no response inthe v5 forum I try my luck here :slight_smile: >> >> I just discovered to my amazement that with the rhino render engine we now >> have real time AO in the viewport to our disposition (please see >> attached >> pic.). While this is of course pretty cool I do have 2 questions /wishes: >> >> 1. Since I use v-ray as my render engine, is there any way to turn on AO >> without switching to the native rhino render engine? >> >> 2.It would be great if we could be able to fine tune the AO settings >> (radius, >> opacity, gradient, samples …) is this possible? >> >> thank you for any feedback >> >> Andreas Walther
can vray “support” the skylight for the display engine?
best regards
Andy
