I am still getting adjusted to the new way of setting up VRay since the new sampling stuff.
Now what I was wondering what are the reasons for the defaults in the Global DMC tab?
1) Min Samples 16 - why not 8 like it used to be? Why would I need more to start with?
2) Adaptive Amount: I was usually setting this to 0.95 in older scenes, it renders very fast since the early termination can kick in faster. Why leave it at 0.85? Is it a “fail safe” setting for…I don’t know… difficult scenes/dark scenes?
It seems to be a more reliable value when using something like the irradiance map.
2) Adaptive Amount: I was usually setting this to 0.95 in older scenes, it renders very fast since the early termination can kick in faster. Why leave it at 0.85? Is it a “fail safe” setting for…I don’t know… difficult scenes/dark scenes?The 0.85 value works better if, for any reason, someone is using the irradiance map and also in some cases for volumes.
Note that with the default V-Ray settings, these two values have little to no effect anyways which is why they are hidden.
