reed chairs
ok. figured it out.. it works in 1.09 too!!
thanks a lot!!
regards
S.wolf
great job Gijs I love the chairs.
-dave
Really Amazing. Great lighting and as others have said, the artifacts aren’t even noticeable with all the other great points of your images.
Only critiques are that the mapping of the displacement isn’t equal all around so it make the weave a little unnatural unless this is how they have to create curves with rattan furniture. Also, why are you wasting electricity with that reading light on :wink:
--Jon
Thanks very much for the map. Hope I can use it sometime.
Great rendering too!
:shock: WOW .. very nice!!!
A quick try :stuck_out_tongue:
Thanks a lot mate!! its great!
looks great !! :smile:
what is your Vray version ?
I have 1.09.03r >>
I don’t know why it didn’t work fine with me !
I made the same settings,but no good result :frowning:
what about the dis map tiling ? and the amount of displacing ?
do u have any idea about why it isn’t working fine with me ? :cry:
Me neither :cry:
I’m using vray version 1.09.03n.
but it doesn’t work fine like Gijs and Lupaz.
I think it might be for the reason of changing Tiff file to Jpeg.
Anyone help me?
The streched version look nice too Lupaz. :smile:
Gogator: that’s why I didn’t post a jpeg version :wink:
Topwerk Gijs! :slight_smile: You da man!
Groet!
Metin
hussam, gogator: well, I didn’t use displacement on material editor. Just a vray material, then vray displacement modifier. there I put the map, with 3d displacement, and finaly the uvw map. The uvw map should be quite little, with dimensions near to the map size. That’s it… just regular displacement.
I’m using 1.09.03r too. :?
Gijs: Thnx!
Think we will see a lot of these chairs in future renderings :slight_smile:
wouter
Haha, you can count on it! :slight_smile:
Lupaz, would you mind sharing your displacement settings? Im not happy with my results and yours looks really good!
hey Lupaz ,that’s a good news !!
I’ll have to try it,
thanks… :slight_smile:
Ok, I have found that there is quite a difference in the displacement in the latest beta build. Everything is looking good in 1.09.
Has anyone had any luck repeating this displacment in 1.46.04?
Yes I had no problem repeating it.
I did nothing special, just vraydisplacement with this map, and set the tiling to your liking.
(I converted the tiff to a bmp because max wouldn’t accept the tiff)
wouter
Wouter, I can get it working perfectly with 2d mapping, but when i try to use 3d mapping the results are really poor, can you share your settings for 3d mapping?
Thanks Lupaz ,Gijs :smile:
Ok,
I took the map and converted it to bmp.
I created a torus knot and a box with mapping coordinates.
Made two materials with the same displacement map, but other tiling. It helps to put it in diffuse first to see how it looks like on the model.
Put vray displ mod on each object, with ‘use obj mtl’ on and ‘keep continuity’ also on.
Rest is default!
Make sure you give the box and torus knot enough segements. Else you should raise the max subdivs from the vraydispl map, but it’s better to subdivide the mesh a bit more (according to the manual).
wouter
