Reflection below 1.0 is missing
Hello
Let me introduce you to my problem:
I’ve got one vray plane light on my scene. First image shows all specular, reflection and diffuse on. Second only the specular on.
If I set the wall glossiness to 1 the reflection is ok, but if I decrease it to below 1.0 the reflection disappear.
In the Attachments I prepared some photo of problem.
Is that intentional or is there a bug somewhere?
I’ve got 3ds max 2014 sp5 and Vray 3.2.01
Greetings
Maybe you worded it incorrectly in the images but you shouldn’t be seeing any reflection in the specular element at all. It’s a bit confusing what’s going on.
I Was chcecking that a lot of times. And every time on every scene this problem reapeats. I think the reflection should be blurred if I go below 1.0 glossiness.
The images shows RGB pass only. Not reflection and specular.
Thanks for Reply
Would be best to post a scene; not really sure right away what the issue is.
Ok, I will send the file to support email
