Reflection Problem
Hello everyone , I have had problems with reflection for some " points of light " . I have had this problem only in this view . I tweaked the MAX RAY INTENS . But I have not solved . Do you think to solve the problem I have to modify the MAX RAY INTENS ?
sorry for my poor language ,and thanks for help
Have you tried enabling SubPixel mapping and Clamp ?
Also you can try to uncheck Probabilistic lights if enabled.
I 've tried but I have not solved!
now I do other test.
thanks for help
Thanks for your reply.
Any chance to send us the scene file to run a test here ? You can check a few render elements in order to be sure that those artifacts are actually generated by the reflection rays - GI, Reflection, Lighting, Specular.
