I have a small problem with my reflection. as you can see on the countertop and the kitchen doors there is some reflection of a car and some flowers. this is actually the bitmap that i am using as a background, placed in the max enviorment slot. this is not what i want. I now with the max raytrace you could say that it must not use the enviorment for the reflection is there a similair solution for Vray or am i something missing here.
Simply put whatever you want to be the reflection into VRays Environment override slots in the REnder Dialogue. Then the Max environment is shown in the background and the VRay one is used for reflections/refractions.
Regards,
Thorsten
Edit: As an additional sidenote you can also do this on a “per material” basis by putting any map into the mat’s Environment slot.
