I´m not sure if anyone already mentioned this, but glossiness refraction doesn´t work in latest daily build. I´ve tried couple examples and still the same result.
in alpha v3 glossiness works
weird.. could you upload your scene?
works for me, what build timestamp are you using?
doesn’t work in latest legacy build, anything below 1.0 refraction glossiness breaks the shader
I modify my old post!
New HD cache is also used to clean the reflections? Render time is now significantly more!
I´m using build from yesterday in max 2013 with win7 64bit and doesn´t work for me at all.. I´ve tried PT+HD, PT+PT and nothing
scene posted by polymax ended up with same result
Mysticism! My “Build timestamp: Mar 4 2013 23:09:48”. You can share yours scene, I will test it?
ok, problem solved, and guess what
I just restarted max ![]()
I don’t even…
LOL :D:D… Anyway, refraction glossines doesn’t work for me no matter what I do. And if I’m not using reflection, only refraction and set refr. gloss below 1.0 the shader is just black…
can you update legacy build, if this isn’t happening in regular newest?
it’s updated
Great, thanks.. I’ll check on it and report…
Refraction Glossiness is working again in mar 6 2012 build also I have no more fireflies with max sample intensity 10 ![]()
that is, it is not a bug?
Okay, I understand now, thanks for the clarifications :)!!!
But glossy now do not work correctly with interpolation parameters by default!
0 disables it because the spinner cannot go to infinity. So I set it so that 0 == infinity.
It is not related to the HD cache glossy problem, but it is also strange that the value o 10 clips it so much
Fixed
