Whenever I am using distributed rendering and try to region render the slave buckets will render drastically darker. ONLY when region rendering. Everything is pathed properly and all nodes are on V-Ray 3.60.04. I have attached some images with DR buckets as well to illustrate the issue. A work around I have found is the load the LC from file, but this issue really needs to be resolved in V-Ray 3. Is there already a solution for this problem, I couldn’t seem to find one. I have been having this issue for months and it really slows down my workflow.
A secondary issue also illustrated here is when region rendering it will clear the image behind and not save over it. Is there a fix for that as well?
