Relief Mapping
Normal mapping is out, relief mapping is in. This is some serious bump.
In quick testing it is compatible with V-Ray & V-Ray lights, shadows, mats and GI.
Check out http://fabio.policarpo.nom.br/files/3DSMax\_ReliefMapping.zip
authors site http://fabio.policarpo.nom.br/relief/index.htm
Pretty cool stuff. Can’t wait to try it out.
thanks
Amazing, can’t wait too :smile:
waouw!! it’s very fast 8)
if you do an environment light only render its not taking the mapping into account really. i havent tested with a dome light but i assume since the dome light is a light source then it will work. i was just using the environment slot.
Yes, it only creates it’s own self shadow correctly even with a dome light. Still it is fast and could work well in many situations.
Thanks Eric,
Sounds very good..
Have do you create those colorful relief maps with photoshop ?
Hi muzzy,
I did not create the maps (normal maps) or the plugin for that matter.
Here is an tutorial on creating normal maps http://66.70.170.53/Ryan/nrmphoto/nrmphoto.html
so this is graphic card driven then ?
its GPU programming reworked to be rendered by the cpu for rendertime effect not realtime effect
cool…pity my card isn’t the right one
Thanks Eric, I will take a look at that
