Remove Interpolated reflection/refraction
I have tried to remove all interpolated reflection/reflections from a scene with a lot of materials.
However when I am rendering it still does the interpolated passes, Is there a script or something that can check or find materials with this option checked?
This drives me crazy.
-Tom
VMC can edit multiple values at once for a whole scene including reflect interpolation and refract interpolation, you will have to run the script a few times with the different default values you have in mind for each option but it will get the job done in a few seconds. http://www.scriptspot.com/3ds-max/scripts/vmc-vray-material-control
Thanks, I just found the last material with interpolation - finally!
It would be nice for the next time tough..
-Tom
VMC is a must for batch material changes.
Next time use this:
(---subdivs
val = off
vmtl = getClassInstances VRayMtl
for i in vmtl do i.reflection_useInterpolation = val
    for i in vmtl do i.refraction_useInterpolation = val
