render abort maxscript problem
hi,
have a problem to abort maxscript controlled rendering. Normaly I can use the for example … bm = render cancelled:&wasCancelled …
and then I can check is wasCancelled is true.
But if abort corona rendering with “esc” nothing happens the var wasCancelled stay “false”.
How can I use the “cancelled” variable together with corona or is there an other way?
This is by design: if I would told 3dsmax that the render got cancelled, it would not save result image and display rendertime in status bar
So. I am doing a batch render script here using corona as main render, and i am experiencing similar problem… So, there´s not solution ?
  I need a cancel function, cause if i send like 15 cameras to render, an something went wrong i need to cancel it...
