Hi there, I’m using H17.5.425 and VRay 4.30.1 - I’m switching the read mode on my cached geo to Packed Disk Sequence and my renders are turning blank/black. Is this supposed to be a supported feature, or is there something I need to do to make these visible?
I can see the cache moving in viewport, and can render via geo or even packed disk primitive - so the cache is good - it’s just the packed disk sequence load mode that doesnt’ seem to be cooperating.
Aaaah that makes sense- thanks for the input!
Hi @bender83 , like @david.anastacio said, V-Ray can’t render bgeos dirctly, if you want to use cahced geometry you should use alembic or vrproxy.
bender83, it should render packed disk / disk sequence, but bgeo contents will be unpacked into the vrscene file.
Could you send me a hip file showing the issue?
Sorry I just saw this! Yes, that was correct - i wasn’t aware that the bgeos get written as geo to the vrscene -that’s all that was happening that I didnt expect
