we just encounter a really strange behavior: When we disable most of the render elements the render time reduce from 77min to 35min.
Using Maya 2016 Ext1+SP4 with official V-Ray build 3.10.01 on Windows 7.
The effect happen on three machines.
The scene uses the PhysicalCamera and MotionBlur. First the render elements ExtraTex (with VRayDirt), Reflect and MaterialID was enabled. After we disabled the Reflect and ExtraTex elements the machines render double as fast.
Image output is full float exr.
Is this a known issue? I thought that the render elements are shifting the render time only a little bit, mostly because more file need to be written out.
Thanks for any enlightenment,
Lars
