Hi All,
Just had this error start since loading Sp1. Its happening when I submit an IR prepass to the network with BB. It renders the IR prepass then errors;
Task error: Could not read/write file type: C:\Program Files\Autodesk\3dsmax8\renderoutput
I have narrowed this down to the fact that I have some render elements set up for when I render the image sequence, and they are messing up the IR prepass.
Is this a vray error or max? Is there a way to change this to work? Maybe disable the save location in the elements tab?
