Hi Guys!
For of all thanks a lot for all the previous help in sorting out issues. You guys are great!
I have a latest stable Vray for Rhino 5 4.10.01 (Sept 24 2019 release)
The render elements roll-out in the frame buffer seems to be stuck and not possible to toggle between the various render elements.
This seems to the issue also for the nightly build for me.
B Maio
Hello, Maio,
I assume you are using Windows 7 or 8.1? If this is the case, then be advised there’s a bug causing the dropdown lists to sink below the VFB window. It will be amended in the upcoming minor update v4.10.02. In the meantime, you can work around this by clicking once on the active render channel name and then navigate between channels using the Up or Down arrows. Apologies for any inconvenience this issue may have caused.
Kind regards,
Peter
Hi Peter,
Yes, I’m using Windows 7. I did manage to toggle through them with my scroll wheel.
Thanks.
