Render Fail... Invalid type? please help...
Please can you help… file fails to render and I can’t understand the error log.
Thanks in advance
Made it after UIManager.initialize
C:\ProgramData\ASGVIS\Python26\Lib\site-packages\Ft\Xml\InputSource.py:346: DeprecationWarning: functions overriding warnings.showwarning() must support the ‘line’ argument
FtWarning, 2)
FtWarning: Creation of InputSource without a URI
Entering renderArchive
About to start readArchive - C:\ProgramData/ASGVIS/VfS/current_skp.xml
5.897000 seconds is how long it took to read C:\ProgramData/ASGVIS/VfS/current_skp.xml
0.031000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
(to ensure this process goes as quickly as possible, please be sure all references to external texture files are correct prior to rendering)
0.890000 seconds is how long it took to add the plugins to our renderer
5.085000 seconds is how long it took to render
13.915000 seconds is how long it took to read C:\ProgramData/ASGVIS/VfS/current_skp.xml
2.683000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
Traceback (most recent call last):
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayplugin.py”, line 215, in add_to_renderer
vray_param = param.to_vray_param(renderer)
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayplugin.py”, line 92, in to_vray_param
return self.value.to_vray_param(self.name, renderer, final_gamma )
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vraytypes.py”, line 348, in to_vray_param
return PyVRay.VUtils.DefStringParam(name, self.to_vray(renderer))
TypeError: argument 2 of PyVRay.DefStringParam() has an invalid type
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayrender.py”, line 328, in render
self.addAssetsToRenderer( self )
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayrender.py”, line 102, in addAssetsToRenderer
ref.plugin.add_to_renderer( self )
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayrender.py”, line 408, in renderArchive
self.render()
