Render Hidden Lights OFF - Option to Bypass Hidden by Category
It would be great to have an option for when you have render hidden lights OFF that it will ignore/bypass them being hidden in the display category level in Max. That way you can toggle the drawing of any lights in you viewports but still have V-Ray only render the ones that are unhidden at the node/layer level. For me using lights category-level hide is always about reducing viewport clutter and never about wanting to disable the effect of the lights.
indeed, the .ishidden property stays false when hiding by category.
As a temporary workaround, add the two attached scripts to the pre and post render slots, and you’re set. :slight_smile:
Just so you know what they do without running them:
the Pre-Render one:
    global wereLightsHidden = hideByCategory.lights --store the state in a global variable
    hideByCategory.lights = false --turn hide by category off for lights
The Post-Render one:
    if wereLightsHidden != undefined do --verify the global variable still exists
        hideByCategory.lights = wereLightsHidden     --set the category hiding to what it was before rendering
They should not error, regardless of mistreatment. At most, they won’t do the re-hiding post render.
renderScripts.zip (527 Bytes)
