Hallo,
I have fixed the render queue scripts from David Rutten now. The render queue script is missing at his homepage. I have the feeling, Davids has forgettent to post it. So, here all four scripts with Davids old gelfing toolbar icons. I have compress the toolbar - smaller and less buttons.
This script allow to render different camera views of a rhino scene per automatic script.
I hope some one like it.
-Micha
www.simulacrum.de/download/RenderQueue.tb
Render multiple views per script
Nice work Micha, I really appreciate the work. I was just wandering? this script is not working with your older tip about render view property.
Fore example ?_-ViewportProperties _Size 600 200 _Enter? will keep rendering all of the images in the queue at the resolution of 600 x 200, even if the other render view ports have another resolution? Do you think it?s possible to ad resolution part to the script?
if we have a queue like this:
perp_01 600x200
perp_02 600x600
perp_03 3000x1000
then we just could use the ?_-ViewportProperties _Size xxx xxx _Enter? to adjust the camera/view-port and then we could use the render queue to render them at the right resolution and position?
really nice work thanks
Sorry, I don’t know so much about rhino script. I can not rewrite the script for your resolution use. You could try to find someone at the rhino or rhino plugin forum.
No problemo… it was just a thought.
If I manage to change it I?ll post it
