Render Only Selected Objects
Hi!
The new features to render only selection is very useful.
It has a little limitation: once choosen “Selected” on the Sampler dropdown menu and click render, if the Camera is behind an invisible Planar VrayLight, nothing is rendered.
Sometime to obtein the right light effect or spcular is useful to “bypass” real life set, and put a VrayLight in front of a Camera, and the Camera behind, alto if I want to mantein a high Focal Length value; well in those cases I’d like to be able to use the feature above.
Thank you for any help. I hope I was clear enough.
Yes, we will need to find a solution for this case.
+1
Already submitted sometime ago, since Render Mask feature has become essential for us !
Getting VRay lights “cutting out” objects to be rendered with Render Mask is really a pain … it would be awesome if you guys could solve that !! :wink:
Thanks !
