I think if my memory serves me right, there was a solution for rendering part of a scene that is not in view of the camera. I have a building that is camera matched to a photo however the top of the building is cut off in the render because the photo was merged from two photos. I don’t want to move the camera as it will alter the perspective.
I remember a script or something that would allow you to render beyond the safe frame?
mmh… it adjusts your camera and render (you set the new output size and it change the focal lenght) so that your old image will be part of the new rendering without changing perspective, just like changing ‘Canvas Size’ in Photoshop, but in 3D. If you use the zoom factor the output size does not change…
If you turn the specify_fov on the Vray camera to on and then set your aperture width in the Render Scene Dialog to the same as your film_gate the overscan script will work just fine.
