Alpha 6
render region in Picture viewer…Crash
R17.053 win7 64 2x Xeon 5680, nvidia 6800, 24 gb ram
tried on two PCs..same Problem. also with different projects…
cheers rob
Alpha 6
cheers rob
And Interactive Render Region is working wrong if you use Copy from IRR button in Render Output
A similar situation. Complete removal of the plug-in and reinstall with the PC did not help. It gives the same message now when installing older versions of alpha//
Hi, could you please send us the _BugReport.txt file? Thank you
will do when i get it again thanks Nikolat
We cannot fix it without a way to reproduce. This is very old, so closing as resolved. If it happens again, feel free to write another bug report.
