never seen this before, been happening lately, is this a bug? as you can see the grey parts is what am rendering but leaves from the trees are also rendering which i don’t have selected
Did you start with a blank frame buffer?
i rendered the whole scene first then i wanted to render only that roof, so i changed the material and changed the option to selected and selected the roof and the issue started, then i closed it all and re opened max again to try to rule out anything weired and stil the same, the answer is yes, i did try with a blank frame buffer also
Maybe they are part of an opened group or something?
actually no they are not but even if it was, why would render selected respect the fact that its in a group? i mean if the group was open whatever you have selected is what should actually render, not sure but am guessing this is how it should work, gona export and reimport things
Are the leafs with opacity maps ? Because lately (after 3.2) the render mask started to respect semi transparent objects in front of selected geometries.
Yavor
yeah they are! hmm probably that’s the issue, i will test it with a single object and tree after the render is done
actually i am rendering more scenes and one render overall at 4k will take about 35 mins but with render selected as the option am seeing now 3 hours for a render, idk what’s going on but this is crazy
Render selected should not normally increase render time. Could you share (parts of) the scene so that we check what’s going on ?
ofcoarse, i can send the entire file and the other one too giving issues, can i have an email to send it to, i will upload it to dropbox
You can send links to yavor.rubenov at chaosgroup.com or to support at chaosgroup.com and mention this thread.
Also - mention which object you are selecting to get those big render times.
no problem, will do today
files sent
Thank you - files received.
There is definitely some issue with the trees in mid left edge of the scene - Group7 and Group8 - without them the render selected finishes very quick. I’ll have to check why that happens and will write back here.
As a bit of a workaround - you could reverse the bucket sequence. Those slow buckets are in the beginning and at least in my tests - they get stuck and I get low CPU utilization. If i reverse the bucket sequence - the slow buckets are in the end, they get split and render faster ![]()
Also decreasing the Max. transp. levels in the Global switches helps..
Yavor
ahh thanks! was thinking those are the trees but i couldnt replace them, i wonder what specifically with the tree is causing it, will waite on you to see
