Hi
I’m trying to find a solution to render some concepts over a white background.
I’ve been using
Primary:Ir map Secondary: L C.
Image Sampler: fixed
Filter: Catmull-Rom
Camera settings:
F-Numbers: 1
Shutter Speed: 200 to 350
ISO:100
the results are terrible
can anyone give me some hints, please?
test file:
http://tavaresdacruz.com/vray/A\_01\_w.zip
http://tavaresdacruz.com/vray/01.jpg
http://tavaresdacruz.com/vray/02.jpg
Best regards
Tavares
Could you pop up some images showing what’s terrible? Ideally turn on some render elements (vraylighting, vrayglobalillumination, vrayreflection,vrayspecular) so we can chase down the problem!
Thanks joconnell
I added 2 images on 1st post.
Is it the graininess you’re seeing being the problem? where is the main light in the scene coming from? A dome light?
i made several tests
dome
planes
and finnaly no light at all
i need to get several infographic bases, as clean as possible, white background, and “white or light grey models”, This is the major problem.
When i use some materials, based on bitmaps i can get acceptable results over white background, as you can see on link below
“white or light grey models”…i’m so far to get it…and i need it badly.
Simple - any of your reflective materials have the default amount of reflection samples, 8 won’t be enough.
For your floor material (material 7) I’ve upped the reflection samples to 32 and for the glass material for the office with the three seats (material 21) I’ve upped the reflection samples to 32 and the refraction samples to 64.
Disable vignetting in your vraycamera and do it in post if you need it.
