Render shadows only
Hi Coronas
this topic i saw before but didn’t solve the problem.
i need to render only the shadows that is in the plane.. i use only HDRI for lighting
hope someone have detailed steps for this
many thanks
There are many ways to approach this, but it depends on your workflow.
You can proceed and apply a “Corona ShadowCatcherMtl” to your plane, change your Alpha mode to “For Compositing”.
On your render settings change your “Render Selected” mode as view-port selection, select your plane and press render.
On your alpha channel you should only be able to see the shadow being cast from your object to the plane, save as png,tga or tiff with alpha channel.
shadows_only.max (1.2 MB)
Thanks alot Corona team..LOve u guys with ur super fast respond
and for ur accuracy in explaining ..
but i’d love to expand my knowledge if u have time to share other workflows..
i’m using 3dsmax
KR,
