Render wrong buckets, looks a little correct but not 100%
Hi.
I have a problem with my renders. Some buckets does not show up correct. What can be the problem.?
https://www.dropbox.com/s/qmuuzij21jekwm7/wrong%20looking%20buckets.PNG?m
Are you using distributed rendering? Looks like some of the render nodes can’t find the textures. (Or they have different vray versions.)
Yes. But I have latest Vray on both.
when I render with lower settings, I don’t have the same problem.
Do you have any warnings in the V-Ray Log screen?
Be sure that all additional plugins (if such are used) are installed to both of the machines.
Do you use a preset for the lower settings?
I think I might have solved my problem.
I had to update my forest pro on the render slave.
But know I am dealing with crashes during rendering. Almost at the end of the render:(
