So I am about to try to region render via command line. I had a few questions since I haven’t done this before.
If I leave out something from the command line such as -cam cameraShape, will V-Ray use the render settings stored in the mb file? I am cutting the render into 4 chucks.
The -reg option does region rendering, not crop rendering (which is what you need). You will still get an image with the full resolution, but with only the region rendered in it.
The easiest way to render a large resolution image is to use a .vrimg file output, turn on the V-Ray VFB and set the “memory frame buffer” option in the V-Ray Common tab of the Render Settings to either “None” or “Preview”. Then use vrimg2exr to convert the result to an OpenEXR file.
The other option is to render with the standalone version of V-Ray, which has command-line options for both crop and region rendering.
Thanks Vlado. I will try rendering to vrimg first, then if that doesn’t work, I will do standalone. Will the standalone grab the stored render globals, or will I have to specify everything at the command line? If I do standalone, is crop all I need with the same format as -reg ?
Yes, more or less. The numbers are left;top;right;bottom with (0,0) being the top-left corner of the image, which is somewhat different than the -reg option.
Is there any limit in terms of large resolution? Ihave the crazy idea of rendering a 160k by 26k image with VRay
Should that be possible with one go, or is splitting the image the only option here?
