Request for a Vray Object Properties script, please
Hi all,
Is there a -knowledgeable- kind soul that could make a macro script to use as a toolbar button, to “Toggle” between the states shown in the picture bellow?
Basically, what I am looking for, is an instant toggle on/off button for the two Matte properties in the V-Ray object panel, a -1/1 toggle for the Alpha Contribution and a 0/1 toggle for the three Reflection/Refraction/GI entries; all toggled with one single click, with no UI involved.
Would this be possible ?
Thanks in advance…
Greg
attached .
vrayPropsToggler_001.zip (920 Bytes)
You’re my hero!
Thanks a mill, much appreciated!
Works like charm!
Do you think this could become a single button on a toolbar directly, instead of opening it’s own popup UI with the two buttons inside?
No worries if It’s not possible; it works great as is, cause I can keep it open and work away.
The toggling could work, but it would get messy quickly in mixed-case situations (f.e. where the top part is set but not the bottom).
The UI takes up hardly any memory or space, though. :slight_smile:
Oooo…that’s useful for sure. Thanks for the post and solution :slight_smile:
You’re welcome.
Notice that if you open the script, there is a list of all the V-Ray properties at their defaults, so it ought to be trivial to extend/change the script.
Thanks a million!
It’s super useful and using it already!
It’s perfect as it is, no worries.
I so wish I could have the time to learn how to code in Max, but thankfully there are awesome people like yourself who help out in the time of need…
