(Resolved) VFB OCIO switch
Using the environment variable “VRAY_VFB_OCIO=1” is not making the VFB default to OCIO, sRGB is still ON by default in the “Display Correction”.
In addition to setting an OCIO path, I’m also using:
VRAY_VFB_OCIO = “1”
VRAY_VFB_OCIO_INPUT_COLORSPACE = “ACES - ACEScg”
VRAY_VFB_OCIO_VIEW_TRANSFORM = “ARRI 3D”
The input colorspace and view transforms are working as they are correctly set after switching from sRGB to OCIO.
Best,
David.
@david.anastacio hi ! looks interesting. do you put this var in the vray json file ?
Indeed the new frame buffer doesn’t respect the VRAY_VFB_OCIO environment variable. This is fixed in our internal builds and should soon reach the nightlies.
Yavor
hi, just add this variables to your houdini.env, in addition you also need the “OCIO” variable with the path to your OCIO config.
Ok, cool, thanks for letting me know. Any idea when by the way? And can we get a heads-up when in gets to the nightlies?
Best,
David.
This bug has been resolved, latest nightlies. Thanks.
