Revit Cloud Model / Enscape Materials Error
I have working in a Revit cloud model with other users. I have created in this model several materials using the Enscape Material Library, adding bump and displacement images (This images are in Google Drive where every user has access to it). The problem is when other user starts Enscape all the materials I’ve created doesn’t appear, everything is white. When you see into the material editor all the textures are lost, even if the material comes from the Enscape Material Library.
If anyone knows how to fix this error I will appreciate that.
Johan.
:revit:
Everyone needs a locally synced folder to your Google Drive where the materials are stored. Each users will need to map an additional render path via Revit settings to the locally synced folder.
