how do you guys deal with rgb values out of e.g. photoshop to LWF in max?
I mean the values from 0-255 in max doesn’t match the values out of any app, when working in LWF, it would get brighter (gamma corrected). how do I get the right values? is there a workaround or a trick to match the exact values?
The vray colour map has a gamma setting so you can copy and paste your photoshop values into the colour swatch then use the gamma spinner to tell vray what gamma to apply - after that it’s a case of getting your exposure correct to make sure your colour doesn’t burn out.
As a direct answer to your question, 2.2. But you will also need the “gamma correction” type set to “specify” and you will have to put the color to the slot again after that has been changed. Usually once I set it, it becomes set for any others I create in my scene thereafter.
EDIT: Did you know that using these settings will also wash out your grayscale values and procedural maps as well? You will notice the shift most promenantly in gradients, and the only way I have found to fix it is by using the ColorCorrect tool which affects the complete operation of the gradient, rather than just the input colors. If you find yourself having to drastically increase bump values in order for your textures to show up, this is probably exactly what is happening to you.
I think what the maxer is saying and my understanding of the vray colour, is that the gamma settings don’t actually change the colour values in any way except in how they are displayed. The Gamma settings in vray colour are pretty useless it appears (I hope I’m wrong…), I thought it would apply the gamma but it doesn’t appear that it does. It’s not really documented either.
So you still have to do a conversion with colour correct or a gamma colour correction script to get 2.2 adjusted colours
Maybe they can change this or add a map to apply gamma in a future version.. Vlado?
I to had a try with the gamma 2.2 settings it appears alright in max but when i opened it in photoshop its was al to dark. is there something i missed?? whe still work with max6 at my wrokplace so maybe thats the problem??
did you render with max FB or vray Framebuffer?
if you rendered with MFB then did you saved the image with gamma 2.2?
in the save dialog you have to check “Override” and put in 2.2 for gamma. then it should appear right.
Sorry I’m a bit late on this one but this can be done with the VRayColor map if you follow these steps.
1. Put a VRayColor map in the diffuse slot.
2. Enter your photoshop RGB values into VRayColor.
3. Set gamma correction to ‘specify’.
4. Type 0.4545 into gamma value.
5. Right click over the VrayColor chip (see diagram) and select ‘copy’.
6. Go back up to the top level of your material and right click over the diffuse colour chip and select ‘paste’.
7. Go to the Maps section of the material and untick the diffuse map.
You now have the corrected colour in the diffuse slot of your material!
Does that fix the problem or have I completely misunderstood the problem, again.
I get the same result without all of the extra steps :
1. Set the VRayColor to Specify, Gamma to 2.2, then input your RGB value. Just leave this in the diffuse slot, top level or not.
If you use the other method for more than one color in a session, you will have to set the Gamma back to 1.0 before putting in your next RGB value. This is because it seems that the VRayColor map is smart and will make the .4545 adjustment to all existing VRayColor maps as well as any subsequently created…which leads me to believe that it has further use than as a simple color calculator.
I just tried this again as it definitely did not work in the past, the specify value would not return up the stack. it appears this is working in the latest release, happy days.
Maxer here is the script, I don’t remember where I got it from.
on gamma_corrector open do
calculate_gamma cp1 cp2 spn1.value
on cp1 changed col do
on spn1 changed val do
on cp2 changed col do
