Just wondering if there will be support for Rhino Nature plugin coming?
@officeBKK , thanks a lot for your inquiry.
We want to eventually provide a scatter tool ourselves natively through Enscape, but I will also gladly forward your wish to have this new Rhino addition supported if it won’t work straight out of the box. I appreciate your input!
Rhino Nature is awesome! You should really consider supporting it…
Noted, thank you.
wow!!! scatter tool would be awesomeeeeeeeee !!!
It’s just a matter of time - Stay tuned for future updates!
Yes it’ll be awesome to have a scatter too for enscape as well. But yes support for Rhino nature would be great too!
Forwarded, thank you too!
+1
+1
Rhino.Nature support please
Will be forwarded as well, thanks!
+1
@FelipeZ @huss191998 @gautier_2 @Tearch @officeBKK @jeriel_castillolluberes @andreas Hi everyone. Id like to understand the request from you all for Nature support.
I’ve managed to use it with Enscape Assets, and have successfully created instances of the Enscape Assets over a surface using Nature.
If I remember correctly when I was looking at this, Enscape does not display the assets that are shipped with Nature itself though. Although I cant remember if that is entirely correct. Is that what the issue is for you all?
Can you please clarify this point for me? That would be most helpful. Thanks in advance.
Thanks for listening to us @Pete_Chamberlain @Demian_Gutberlet
We meant the support for RhinoNature library without baking all geometry to work seamlessly like (vray,octane and Thea) in full and proxy geomtry version and interactive rendering, so we need a direct bridge to work with enscape ,as we need a direct link where I can save tons of RAM and diskspace and ofc time because of speed between change/rendering iterations.
Yes, that’s what I thought was the issue. So, Nature is essentially showing preview / proxy geometry from the RhinoNatureLib until you bake it out? If i understand it correctly, and that’s what you want Enscape to support? (sorry my RhinoNature trial has run out, I can’t test it again right now - requested a license from the Nature author ;).
Can’t promise anything, but will certainly take a closer look at this.
You got It @Pete_Chamberlain , Check this screenshots, and check this also https://help.rhinonature.com/api/integrations
Enscape is My favorite Render Engine and I hope you could collaborate with each other to make the awesomeness happens
Sir!!! What about scattering tool for enscape? any news?
Yea, ok. Thanks for the API link. I must have missed that.
In regards to Enscape scattering tool:
Our preview 7 which should be released later today will also already allow you to play around with the new Multi Asset Placement tool. Give it a shot yourself and feel free to share any Feedback with us if you like.
