Rotate Asset.
Why can’t I rotate Assets on the Z-axis?
Example I wanted an asset like horizontal climbing grass to put on a gazebo or a patio. How can I get horizontal grass plants for a patio?
Rotate Asset.
Hey @ab68
can you please tell me what design software you’re using Enscape with?
Revit 2023 and Enscape last version.
L’inserimento di Asset è ciò che rende i rendering belli. Se inserisco Asset da Revit ok, posso ruotare la risorsa Asset con la barra spaziatrice di Revit ogni 90 gradi. Ma è molto lento. L’inserimento di Asset all’interno di Enscape è molto più veloce.
I see, thank you for the clarification. So you have found a solution for it in Revit and it’s all about optimizing workflows and saving time by doing it directly in Enscape.
Can I please ask you to explain this in our Ideas Portal?
https://chaosenscape.ideas.aha.io/
Just click “+ Add a new idea” and share your request with the team. Thank you! And let me know if you run into issues!
So it is not expected today right?
The space bar command is one of the great and simple things in Revit orienting an object quickly every 90° is a great thing and I think easily implementable by you.
But I still have the problem of the Enscape panel that does not remain fixed on my desktop and what is worrying is the automatic Enscape Bump does not remain in memory or saved
