i am interessted by the unreal vray plugin , i working specially with CAD file,
i downloaded the 30 day trial, but i don’t see on the documentation to have the possibiility to change the rounded Edges With
it is possible with v-Ray 5 in Unreal ?
thank you.
Hava a nice day.
Best Regards
Daniel
Hi Daniel,
Rounded edges is not supported in V-Ray materials in Unreal. How are you importing your CAD files: with Datasmith or with VRScene? If you are using a VRScene there is somewhat of a workaround:
- you set your material to have rounded corners in Max for example
- export a vrscene and import it in UE
- in the Content Browser locate the material that have those rounded edges applied
- Right click on it and enable Render material from .vrscene (V-Ray for Unreal)
- Render the scene and you should see your model have rounded corners
Unfortunately there isn’t a way to visualize the rounded corners effect in the UE viewport in real-time but it is something that we have in mind to implement in the future.
Alexander
