RPM Pass per light script...
i’m working on this little tool and could really use some guidance. I worked out the RPM related kinks with Grant at RPM but this is still not fully functioning.
It will create a Property CapSet for all lights in the scene. Then it creates a single pass for each light and attempts to turn all but that light off…
It works to turn VRaySun off, but does not turn it back on again…
Also, it is not working with daylight systems. i.e. $[2].enabled = true
It still needs a lot of work beyond these issues. I have yet to take into account the number of existing CapSets.
if not rmpasses.open do RPMdata.RMopenFloater()
global allLights = #()
for a in lights where classof a != Targetobject do --and classof a != objectset
        append allLights a
capSet = RPMCaptureProps.createCaptureObjectSet() -- create a new capture set. Would like to add the Name at this point
lightCapture = RPMCaptureProps.getMyPropDefinitions lightinputarray:#("On") --Define the properties
RPMCaptureProps.assignCaptureProperties #(1) lightCapture --Assign the properties to the capture set. Would like to use the appropriate index here if there were existing CaptureSets
RPMCaptureProps.addObjectsToSet 1 allLights suppressProgress:false -- Add all the lights to the CapSet
--Build a pass for each light
for i = 1 to allLights.count do
    lightname = allLights[i].name
    RPMdata.AddPassSetup setname:lightname noEdit:true
    --turn off all lights
    for k = 1 to allLights.count do
        if (hasproperty allLights[k] "enabled") then allLights[k].enabled = false
        else if (hasproperty allLights[k][2] "enabled") then allLights[k][2].enabled = false
            else allLights[k].on = false
    --turn on the corrisponding Light
    if (hasproperty allLights[i] "enabled") then allLights[i].enabled = true
        else if (hasproperty allLights[i][2] "enabled") then allLights[i][2].enabled = true
            else allLights[i].on = true
    RPMCaptureProps.OPcapture_object allLights
rmpasses.close()
For anyone interested, Grant from RPM worked it out for me. If you have RPM, this will create one pass per light, including any light with the “enabled” property instead of “on”
enjoy!
p.s. if you don’t have RenderPassManager, have a look here. It is a major lifesaver and the support is amazing.
        append allLights a
global existPasses = RPMdata.GetPassCount() --store the existing number of passes
print ("PassCount:" + existPasses as string)
haveCreatedLightSet = false;
    RPMdata.AddPassSetup setname:lightname noEdit:true force:true -- the force stops it asking about creating a camera
    if haveCreatedLightSet == false do -- if we call these before a pass is created it errors.
        -- assume there is only one
        RPMCaptureProps.setCapSetName (RPMCaptureProps.getnumcapsets()) "Lights"
        lightCapture = RPMCaptureProps.getMyPropDefinitions lightinputarray:#("On") custominputarray:#("enabled")--Define the properties
        -- work around the problem that the last call didn't actually do what it should have and add the supplied custom property:
        lightCapture[7] = #("enabled")
        RPMCaptureProps.assignCaptureProperties #(RPMCaptureProps.getnumcapsets()) lightCapture --Assign the properties to the capture set. Would like to use the appropriate index here if there were existing CaptureSets
        RPMCaptureProps.addObjectsToSet (RPMCaptureProps.getnumcapsets()) allLights suppressProgress:false -- Add all the lights to the CapSet
        haveCreatedLightSet = true;
    for k = 1 to allLights.count do --turn off all lights
        if isproperty allLights[k] #on then (
            allLights[k].on = false --turn on the corrisponding Light
        else if isproperty allLights[k] #enabled do(
            allLights[k].enabled = false --turn on the corrisponding Light
    if isproperty allLights[i] #on then (
        allLights[i].on = true --turn on the corrisponding Light
    else if isproperty allLights[i] #enabled do(
        allLights[i].enabled = true --turn on the corrisponding Light
rmpasses.close()
Awesome -that will be very handy. Thanks for the share!
b
No problem.
The one thing it needs is to turn off the environment map in the common params. when i have time, I’ll look into it. If anyone solves it in the mean time, I’d love to have an update.
