RT 3.20.03 Settings Greyed Out
Hey there,
Probably a simple fix, but can’t work it out.
When i use RT as the active shade renderer, and go into the settings under render dialogue, all of my settings are greyed out and arent accessible.
So as it is for example, i cant turn on proxy objects etc.
jc
Maybe a stupid question, but was active shade running while you tried to change these settings? These settings are unavailable while it’s running. You’d need to close the active shade window, change the settings and turn it on again. Otherwise I have no idea what the problem is.
Yes, exactly. Some of the settings are only editable while the render is stopped.
thanks auke and tashko, spot on!! first time i’ve used RT!!
