Is anyone having trouble with showing recently done renders in Max 2017?
The Corona VFB always shows up during render, but if I close the window, it is a goner. I can’t even reopen it to save an image that has been previously calculated.
is anyone else experiencing this behaviour?
I’ve checked to see if it opens off screen with Alt+Space, but it is a no go.
As you can imagine it is tricky to always have to do a new render to be able to access the framebuffer…
Kind regards and thanks in advance!
RB
What happens if you go to render setup > show vfb?
Also 3ds Max Rendering > Show rendered frame window (I am not sure about the exact name - 3ds max currently closed ) - it should show the image in 3ds Max VFB.
