As you will notice the glass with glossines 0.2 in the mirror is not reflected, how do I solve the problem?
C4d r21
Corona 6
This is a known issue. I had the same problem a few days ago.
I don’t know, what the best workaround could be, to be honest..
Make the mirror reflection glossiness 1.0 or enable caustics in the frosted material.
It’s a known issue:
- Appearance of refractive materials changes when reflection glossiness other than 1 is used (even if it’s set to 0,999). The workaround here is to enable caustics for the refractive material.
