Save Animation as CXR?
I’m running Corona on a Mac, OS 10.12.4.
Build timestamp: Aug 30 2019 18:32:59
Version: 5.0 daily Aug 30 2019 (core 5 (DailyBuild Aug 30 2019))
Cinema version: R20.059 CINEMA 4D Studio
I wanted to render an animation and use the Gather Data for Later feature of the Denoiser so we can experiment with the looks. This feature only works if you save an image as a .CXR file which I can do if the Save button is held down in the VFB. I see the option to “Automatic save on render end” setting, but there isn’t an option for the format of that save. As far as I know, I would need that .CXR format.
Is this possible in the current state of Corona?
Hey,
the option “Automatic save on render end” does actually save the CXR-file. So you just need to locate your corona history folder and you will find the CXR files there. Regarding batch-processing, which you want to do, I hope somebody else can chime in and help you out!
C:\Users\Admin\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\corona\history
Cheers,
Ara
