Saving render elements within one EXR when rendering through BACKBURNER
Hello guys,
i am having troubles settign this up…can you please help with the setup?
Martin
rendering to a single EXR via the VrayVFB works just fine via Backburner.
Regards,
Thorsten
i am absolutely sure it works fine, but i just dont know how to set it up :slight_smile: the elements saving.
do i just select the lements in render elements tab?
do i have to add them when saving to exr (save to exr pop up window)?
thanks
Martin
Martin,
- You could select the elements you want in the render elements tab
- Rename the .vrimg extention to .exr in the Vray:Frame Buffer section
Thanks,
Ismail
yo,
i was doing that but i was making the mistake that i ve been also saving through the classical save option in common tab!!! so the vrays EXR has always been overriden by the maxes EXR…
ALL SORTED NOW
