Scatter C4D splines + Render Spline Tag
This setup doesn’t work while it should, no ?
Scattering anything other than splines works though.
Corona 12 update 2 hotfix 1
Cinema 4D 2025.2.1
The setup works with a native Cloner but only if it is set in Instance mode. I guess the Render Spline tag doesn’t support instancing ? It would be dumb.
I guess it should work, unless there are some technical limitations.
It’s logged as (Report ID=CC4D-1041).
