IN archviz films we usually work a lot on cameras in 3ds max and then we import at vantage standalone to configurate the whole scene and render
Because the camera then is recorded in vantage timeline you cannot apply different scene state, like sun timelapse, or sky clouds, or moving objects,or interior lights substates animation,
It would be very helpful if scene states where animated separately in a fourth bar in the timeline.
Plus please make the timeline more usuable, so that we can manipulate the different clips.
Hi digital_technologies,
You already have requested separate track for scene states in your previous posts(https://forums.chaos.com/forum/chaos…-update-button, https://forums.chaos.com/forum/chaos…etter-timeline) and we have it logged under LAV-1661 in our system.
Currently you could animate the sun independently from the scene states when you have it set to Animated Geolocation Sun position mode. The clouds can also be controlled with this mode by setting the Wind speed and Wind direction angle parameters. No other properties can be auto-animated at this moment. But for a more controlled animation you would need a separate scene state track or a way to key frame parameters in the animation editor(LAV-572)
What do you mean different clips? Do you mean different imported vrscenes or recorded cameras or something else?
Alexander
