When I start up Max 2018 I get an error which seems to be linked to VRay… The Maxscript screen pops up and it has the following image below. Does anyone know what should I do to fix this? Since I really don’t understand script language at all…
Thanks!
When the message pops it should contain the full file path to the problem file - could you go there and delete it. It should be called like in the screenshot you’ve posted: __tempSomeNumber.mcr.
Those mcr files are automatically created by Max when reading various scripts (V-Ray ones in this case). If for some reason Max crashes while creating those files you end up with those unfinished files.
Yavor
Thanks Yavor! That solved it! No more annoying messages!!!
Best
Alex
