Shadow/Catcher / light problem, something similar to self shadowing, ideas?
Hi there guys.
I’ve been tinkering a bit trying to achieve a proper matte shadow “state” for objects in the scene so I can render just an object inside the scene maintaining the light around it but getting just the object and the object casted shadows and GI.
So far I tried to di this:
And I get this, wich is a cool beauty, and an uncool alpha.
Now I’m wondering how to avoid all this lighting effect in the environment because I need the object and it’s effect in the rest of the scene (in this case the text) and I need the reflections and the light to be the same as in the actual real scene without shadow catcher, so I need all the objects with the correct material for GI/Reflection/Refraction,and I override this material just for direct.
if I use the shadow catcher in the Global Illumination slot, as you can imagine all the reflections and lighting change, but I get the alpha I need.
So the question is how can I achieve the beauty of the first sample and the alpha of the second sample in the same render?
Best regards!
P.S.: I forgot how to include attachements in line, can someone refresh me this so I can include the pictures in the post?
Hey guys, no ideas here?
Dev team? (Maybe it’s a more appropriated question for you than for artists)
Cheers.
Hey guys, I don’t want this to be dead, dev team, some ideas?
Cheers.
Hi Juan, for your willingness to help recently I feel indebted to try to help you too. :smiley: Can you submit a support ticket at https://coronarenderer.freshdesk.com/support/tickets/new and describe the problem? (you can just copy the stuff from this thread)
Thanks Maru.
Just did it :smiley:
Cheers!
